apartment automation with an apple iBook?
Aug 08, 2006 1 Replies
rbcameron
It depends on whether you can leave the iBook in full time control or you have to disconnect it and take it with you. I use Xtension which requires full time connection. Check out: It's mac only software and there's a limited size demo version you can download (only controls…
Hey guys, Im gonna admit i am extremely new to all of this, but a friend of mine recently got a new X10 setup in his house and it amazed me. I wanted to set up a similar system in my new apartment, but i dont know if it would work with my apple ibook. If someone would be so kind as to just tell me 1. if its possible and 2. what i would need to buy in order to make everything work out
Thanks alot in advance Marc
It's mac only software and there's a limited size demo version you can download (only controls five X10 addresses). Join the discussion/support list and lurk for a while.
As for what you need to buy: see the tutorials on the web site; what you buy will depend on what you want your system to do. A little up front planning will save some cost and frustration later (but might reduce the fun and learning).
No relationship with the software other than a satisfied user.
Bruce
