Activehome
Mar 27, 2005 4 Replies
Jump to replies (4)
I have installed Activehome and I get the following error...
c:\windows\system32\autoexec.nt. The systemfile is not suitable for running MS-DOS and microsoft Windows applications. Choose 'Close' to terminate the application.
How do I fix this. The autoexec.nt file does not exist.....
Thanks Bobby
Forget active home buy a better program like Homeseer. Try looking at X10 forums to see all the problems with Active Home.
You should find under C:\\Windows\\repair a file named autoexec.nt.
Copy it to C:\\Windows\\system32 and it should fix your problem
Hope it helps
Thierry
"Bobby" a écrit dans le message de news: toz1e.4794$ snipped-for-privacy@newssvr11.news.prodigy.com... I have installed Activehome and I get the following error...
Thanks Bobby
go on google and type : x10 forum automation
that will give you about 98 800 link to page that talk about home automation and are located in a forum...
Google is your friend
"Nancy & David"
