120V limit switches
Feb 08, 2006 2 Replies
120V limit switches open original image
So, for over 20 years, there has been a 120V limit switch in the basement of my grandparents house that turns on a light when the door to that small room is opened.
This switch is a plunger with a spring. the plunger is about 1-2cm in diameter and has a throw length of about 5cm. the light is on when the plunger is not pressed in.
I've looked for similar switches and they all seem to be horribly overpriced. Most of the 120V switches i see are between $50 and $75. I've seen a few on ebay for $25ish. toggle switches can be had
Here's one for under 10 bucks that I found by entering "closet light" into Yahoo's search feature:
From:Philip Lewis flip+spiced snipped-for-privacy@andrew.cmu.edu
BruceR++, You are *the* man. ;)
The search term I've been missing is "door switch". Sometimes I get too specific for google and get stuck in my terms. Why I didn't think of 'fridge door switches, i don't know.
Thanks!
