Zonealrm Mailsafe
Aug 16, 2005 3 Replies
Jump to replies (3)
RE: Zonealarm V5.5.094.000
In the Overview | Status screen of Zonealrm it states that Mailsafe has quarantined 12 e-mail attachments.
I can't find them on my hard disk.
Does anyone know where they are stored or how to delete them.
If I can find the folder they are in then deleting them should be easy.
thanks
They should be in the same directory where email attachments normally go for your email program. But they'll be renamed and will end with .zl* where the
  • is a numeral.
Craig
Taking a moment's reflection, nospam mused: | | I can't find them on my hard disk.
Look at your ZA logs. There will be entries for "MailSafe" ... the details will indicate where the files are.
