where is my external dns ?
Jun 11, 2006 2 Replies
Frankster
External simply means anything outside of your LAN controlled environment. Often, people (wrongly) use External and Internal when they really mean Public and Private. That's just a fact of life. Something you should know. You have to read "in context". Typically, your "gateway"…
sorry for asking such a stupid question.
may i know where is my external dns ? is it refer to my local dns server or the gateway ? my config is that w2k pdc is also a dns/dhcp server, previouisly all internet connection connect to firewall and router (gateway).
but now we bypass the router and connet directly to MUX. so where do i go and check the external dns record ?
Typically, your "gateway" would provide either the "External" (outside your LAN) resolution functionality itself, or, at least provide a path to where it could be found (typically your ISP name server assignments - for public Internet stuff).
As far as where you would look for your external DNS... (assuming you mean public here), look to your ISP and/or router DNS config.
-Frank
External (or public) name resolution can be anything from a service on the router/gateway (BAD idea) to a dedicated server in a DMZ to ISP- hosted records.
cu
59cobalt
