Websense and Sonicwall
Mar 02, 2005 1 Replies
I've recently installed a Websense Enterprise server and tried to integrate it with a Pro3060 Sonicwall running the Standard version of the OS. After a short period of time, the Sonicwall freezes and the only way to get it back is to reboot it by pulling the power. I then have to turn the Content Filtering back off on the Sonicwall in order to keep it from crashing. Any ideas or suggestions or similar issues?
Thanks
What version number of the standard OS sonicwall code are you running? there have been some issues with some versions.
I don't know which versions for the standard version have bugs with regards to websense, but I do no that for the enhanced version, all the
2.x revs worked, then it broke with the realease of 3.0.0.1, and did not get fixed until 3.0.0.9.
