WAG54G ADSL Gateway firmware
May 17, 2005 1 Replies
I know this has been raised many times but I am totally confused re the firmware updates for my WAG54G-UK ADSL Gateway. It is V1.2 and I believe this matters.
ACcording to what I can find it has :
Gateway software 1.01.6 (this is also shown as the firmware version in the blue text banner?) Wireless firmware 1.0.4.3
The only firmware update applicable to the UK WAG54G version on the linksys website is 1.00.19??
I am not sure to what this relates and when I applied it in 'blind hope' it crashed half way through and I had to restore the factory default and set everything back up again.
Help
Victor
In message , snipped-for-privacy@luminary.co.uk writes
Point, mine is:
Blue banner shows: Firmware Version 1.02.1
Status Local Network page shows: Software Version 1.02.1, Apr 27 2004 Status Wireless shows: Wireless Firmware Version 1.0.4.3
Not immediately sure which hardware version.
According to:
WAG54G - Wireless-G ADSL Gateway
Firmware Date : 12/18/2004 Firmware File Size : 3.7MB Firmware Version : 1.00.19
Which links to:
I am not sure whether the V2 refers to V1.2 hardware, or what.
doesn't look to have
1.02.1, but does go up to:
WAG54G_AnnexA_ETSI_v1.02.7_03_code.bin 887 KB 12/11/2004 00:00:00
The last zip:
WAG54G_AnnexA_ETSI_v1.02.5_07_code.zip
says:
Linksys, A division of Cisco Systems, Inc.
Product: WAG54G Annex A (European)
Release Date: September 17, 2004, Released as Beta firmware
Classification: Firmware Release History (European versions only)
NOTE: Not for use with Annex B models (E1 and DE)
_________________________________________________________________________ _______ Firmware version 1.02.5
NOTE: Only limited technical support is available for this firmware.
- Added: Backup/Restore function, AP Isolation function, new policy filter function, SNMPv2C support.
- Modified: Enlarge the IP range of Local/Remote Secure Group in VPN settings.
- Fixed: Linux nmap scanning issue.
- Fixed: Fragment issue on PPPoA mode with NAT disabled.
- Fixed: Single port forwarding failure if "External Port" is different from "Internal Port".
- Fixed: Intel UPnP tool not being able to scan the device.
- Fixed: Wireless clients not getting IP via DHCP Relay
- Fixed: PPTP passthrough issues.
- Fixed: Large files FTP in IPSec passthrough(UDP) will be disconnected.
NOTE: DynDNS function built into the firmware may not work properly with this version of firmware. If you experience difficulties, please use the client on the PC.
But obviously 1.02.7 is probably a Beta at best.
If you want to investigate, then start working through:
I am not immediately sure where I got 1.02.1, sorry.
Perhaps the latest production code on is: WAG54G_AnnexA_firmware.zip, which appear to contain v1.00.7 , but it is a bit difficult to tell.
You might want to try asking here:
or here:
But make sure you get EU Annexe A.
Regards
