vpn netgearvs338 and pc client
Nov 10, 2006 3 Replies
Jump to replies (3)
Hi. I have a router fvs338 with the new firmware 2.0 I build a VPN with a "safe Net" client as manual's Netgear explain. The vpn didn 't function correctly and i recive this error in the "vpn logs"
ERROR: Could not find configuration for xxx.xxx.xxx.xxx [500]
With the previous version of firmware i haven't problem. Have anyone, any suggestion?! Thanks a lot.
hi
before u set up the VPN connection
have u ran the VPN wizard on the fvs338?? and r u typing the same preshared key, domain name on the client side
if u have given a name for vpn wizard on the router then please try adding the name1.fvs_local.com in the cleint software and try to connect. it will work
rgds siraj > Hi.
Yes, I beforethe VPN in the Router with the "wizard Configuration" and i configured the VPN client with "name1.fvs_remote.com".. I read the manual of netgear and i build the vpn as netgear explained. Any other ideas!? TKS
snipped-for-privacy@gmail.com ha scritto:
IT Man: did you resolvethis? i am having the same issue =, only with the FVX538.
Netgears support was pretty useless. can anybody help?
r> Yes, I beforethe VPN in the Router with the "wizard Configuration"
