Remove VPN settings from my NS25
Aug 27, 2007 1 Replies
dear guru, i'm new to Netscreen, have set some VPN setting thru the Webinterface, however, cannot see the "remove" or "delete" button. How can I remove those setting/gateway? from web or CLI? please help
Am Mon, 27 Aug 2007 16:56:29 -0700 schrieb Mr_Huang:
Did you built the tunnel policy based or routed? Which OS do you have on the Box? Usually you can remove it in vpn's AutoIKE in the WebUI and in the CLI (preferred) unset vpn "VPNNAME".
