Remove Package Policies in Check Point SmartDashboard
Dec 21, 2004 2 Replies
I'm using Check Point SmartDashboard (NG with Application Intelligence (R55) Build 127) and am trying find a way to remove previously saved Policy Packages. The GUI does not appear to have this option. I've also looked from the Nokia command line, but have not been able to find a way. Anyone know how?
Thanks,
Jeff
jeffrey snipped-for-privacy@hotmail.com pounded out on the keyboard on or about
21-Dec-04 18:31:
Hey, Jeff
In the SmartDashboard, under the File pull-down, you'll find a Delete -> Entire Policy Package This will pop up a window where it will list the policy packages that are available. Select the one you want to delete and you should be all set.
Jeff
Jeff,
Thanks! Right in front of my eyes!
Jeff
