Hello experts, our group is experiencing a strange think when installing R55 (module) on two SUN v240: we have previously installed the management on a Sun v120 without any problem, and installed more firewall clusters on various SUN hw, from Ultra 10 to R220/280, Enterprise 250 and more... We changed many installation cd, also excluding a support error. I 've think about a system environment variable mismatch, but I can understand the error... Patch cluster is correctly installed.
This is the output from /opt/CPInstLog/wrapper_R55.elg:
Preinstalling stage... Found package CPshrd-R55 checking_FP41_prods Checking registry: CPPROD_GetCurrentMSP FW1 1 : NOK : RET_VAL= Checking registry: CPPROD_GetCurrentMSP FG1 1 : NOK : RET_VAL= Checking registry: CPPROD_GetCurrentMSP \\Policy Server\\ 1 : NOK : RET_VAL= Checking registry: CPPROD_GetCurrentMSP UAG 1 : NOK : RET_VAL= Checking registry: CPPROD_GetCurrentMSP RTM 1 : NOK : RET_VAL= Checking registry: CPPROD_GetCurrentMSP PPACK 1 : NOK : RET_VAL= Checking registry: CPPROD_GetCurrentMSP \\Reporting Module\\ 1 : NOK : RET_VAL= Checking registry: CPPROD_GetValue Reporting Module ReportingServer 1
1 : NOK : RET_VAL=Failed to find the value checking_BC_ver checking_configuration Checking registry: CPPROD_IsExpress 1 GET : OK+ : RET_VAL=0 Package CPclnt-41 not found Package CPclnt-50 not found Package CPclnt-53 not found Package CPclnt-54 not found Package CPclnt-R55 not found CLEAN_INSTALL Installing of CPfw1-R55 package
Copyright 1994-2003 Check Point Software Technologies Ltd.
All rights reserved. This product and related documentation are protected by copyright and distributed under licenses restricting their use, copying, distribution, and decompilation. No part of this product or related documentation may be reproduced in any form or by any means without prior written authorization of Check Point. While every precaution has been taken in the preparation of this software package, Check Point assumes no responsibility for errors or omissions. This software package and its features are subject to change without notice. /tmp/installCvaqFg/checkinstallEvaqFg: /opt/CPInstLog/install_fw1_R55.elg: canno t create /tmp/installCvaqFg/checkinstallEvaqFg: /opt/CPInstLog/install_fw1_R55.elg: canno t create /tmp/installCvaqFg/checkinstallEvaqFg: /opt/CPInstLog/install_fw1_R55.elg: canno t create /tmp/installCvaqFg/checkinstallEvaqFg: /opt/CPInstLog/install_fw1_R55.elg: canno t create /tmp/installCvaqFg/checkinstallEvaqFg: /opt/CPInstLog/install_fw1_R55.elg: canno t create /tmp/installCvaqFg/checkinstallEvaqFg: /opt/CPInstLog/install_fw1_R55.elg: canno t create /tmp/installCvaqFg/checkinstallEvaqFg: /opt/CPInstLog/install_fw1_R55.elg: canno t create
**********************ERROR*******************************************
The installation application has detected that you do not have Check Point SVN Foundation NG with Application Intelligence (R55) installed. In order to install VPN-1 Pro NG with Application Intelligence (R55) you must f irst install Check Point SVN Foundation NG with Application Intelligence (R55) . Installation Aborted.
Please ignore the following error message: WRAP_ERR_TRACK_BEGIN (CPfw1-R55)
Processing package instance from
Check Point VPN-1 NG with Application Intelligence (R55) (sparc) 5.0 pkgadd: ERROR: request script did not complete successfully
Installation of failed. No changes were made to the system. WRAP_ERR_TRACK_END (CPfw1-R55)
Enterning to install hotfix section Launching ./HF/CPfw1-50/fw1_hf (Check Point VPN-1 & FireWall-1 NG AI) is not installed on this machine... Execu tion aborted ../HF/CPfw1-50/fw1_hf is not finished OK...
Hope someone can help us... :-(
Thanks in advance! Roberto
