Problems with Intel e1000 on SPLAT and using patch add utility
Apr 26, 2005 0 Replies
Hi all,
I've got a problem with Intel e1000 NIC's on SecurePlatform running Checkpoint R55 AI. My firewall contains two nodes in Active/Standby mode. Each node reports errors (from duplex mismatch on the NICs) and the cluster keeps on failing over from one node to the other.
I've installed the patch from Checkpoint for R55 for the e1000 network card, but while I ran patch add **** I aborted. This resulted in SPLAT thinking that the patch was installed and its not allowing me to re-install the patch (keeps on reporting that the patch has already been installed).
Can somebody assist on how to remove a patch in order to re-apply it? What does the patch utility do and how can I roll back its changes to such a state that I can re-run patch add for the e1000 driver update?
Regards, Gabriel
