Port forwarding to a remote host AND local processing on redhat linux
Sep 27, 2006 5 Replies
Jump to replies (5)
I use kernel 2.4.x. My requirement is to do port forwarding to a remote host AND to process these packets locally.
I tried using iptables for port forwarding. It works. But I can't process these packets locally as well i.e. I need to pass these packets to a local application for further processing in addition to remote host forwarding.
Any other tips other than using iptables? Thanks for the help.
Port Forwarding means address rewriting and that means routing and the packet is processed in the FORWARD chain. You would have to copy the packets before the address rewritten, rewrite the address of one packet and leave the other untouched ... forget it.
Wolfgang
I don't know a possibility to copy packets (with iptables). Therefore I said: 'Forget it'.
Wolfgang
this kind of thing is solved with Proxy solutions, but there's big questions as to WHY one would attempt this data flow. The connection to the client-server imply atomic processing. IF you need some kind of 'back-end' support, it would normally be an extract or secondary process from the original server. Simple dual-logging would be straight from the proxy.
So aga> I use kernel 2.4.x.
