SSH and Port Forwarding on a PIX501
Apr 11, 2006 1 Replies
I have been trying to enable SSH to an offsite PIX with no luck. I get the prompt for user and password, but it does not accept the valid user and pass that is programmed on the PIX.
I have also tried to enable some port forwarding so that I can use PCAnywhere from anywhere. I can see the pca access list count increment each time I try to connect, but no connection ever happens. I have only been able to test this from within my main site address space, and I think that may be confusing things. If someone could just tell me if the config should work, I would appreciate it.
Please, someone, whack me up the side of the head and tell me what I'm missing.
*********Config*********** Building configuration... : Saved : PIX Version 6.3(4) interface ethernet0 auto interface ethernet1 100full nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password xxxxx encrypted passwd xxxxx encrypted hostname Nauvoo-Pix domain-name domain.com clock timezone cst -6 clock summer-time cdt recurring fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names access-list nonat permit ip 10.0.1.0 255.255.255.0 MainIP.0 255.255.255.0 access-list 101 permit ip 10.0.1.0 255.255.255.0 MainIP.0 255.255.255.0 access-list pca permit tcp any interface outside eq pcanywhere-data access-list pca permit udp any interface outside eq pcanywhere-status pager lines 24 mtu outside 1500 mtu inside 1500 ip address outside dhcp setroute ip address inside 10.0.1.10 255.255.255.0 ip audit info action alarm ip audit attack action alarm pdm location MainIP.0 255.255.255.0 outside pdm location MainIP.0 255.255.255.0 inside pdm location 10.0.1.1 255.255.255.255 inside pdm logging informational 100 pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 0 access-list nonat nat (inside) 1 0.0.0.0 0.0.0.0 0 0 static (inside,outside) tcp interface pcanywhere-data 10.0.1.1 pcanywhere-data netmask 255.255.255.255 0 0 static (inside,outside) udp interface pcanywhere-status 10.0.1.1 pcanywhere-status netmask 255.255.255.255 0 0 access-group pca in interface outside timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local aaa authorization command LOCAL ntp server MainIP.1 source outside http server enable http MainIP.0 255.255.255.0 outside http 10.0.1.0 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable sysopt connection permit-ipsec crypto ipsec transform-set lsi esp-3des esp-sha-hmac crypto map lsimap 1 ipsec-isakmp crypto map lsimap 1 match address 101 crypto map lsimap 1 set peer 65.90.50.46 crypto map lsimap 1 set transform-set lsi crypto map lsimap interface outside isakmp enable outside isakmp key ******** address CorpEndIP netmask 255.255.255.255 isakmp policy 9 authentication pre-share isakmp policy 9 encryption 3des isakmp policy 9 hash sha isakmp policy 9 group 2 isakmp policy 9 lifetime 86400 telnet MainIP.0 255.255.255.0 outside telnet 10.0.1.0 255.255.255.0 inside telnet MainIP.0 255.255.255.0 inside telnet timeout 5 ssh MainIP.0 255.255.255.0 outside ssh timeout 5 console timeout 0 dhcpd address 10.0.1.100-10.0.1.131 inside dhcpd lease 3600 dhcpd ping_timeout 750 dhcpd auto_config outside dhcpd enable inside username user password xxxxxx encrypted privilege 15 terminal width 80 : end
********End Config*********
Thanks,
Gordon Montgomery Living Scriptures, Inc snipped-for-privacy@lsi.com (anti spam - replace lsi with livingscriptures) (801) 627-2000
As is always the case, 15 minutes after I post, I find an answer. If I do not have AAA authentication set up specifically for SSH, I need to use PIX as the user name with my telnet password. I thought SSH would use the user programmed near the end of the config.
I still would like a response on the port forwarding though.
Thanks,
