PIX 501 to ASA 5505 - telnet dropping out
Aug 02, 2007 3 Replies
Jump to replies (3)
Hi All,
I have pix vpn'ed to asa over broadband connection using DES. Telnet sessions running over the vpn are, in a pretty random fashion, being dropped at the user side (behind the pix) while appearing to the server (behind the asa) to still be active and keeping the sessions open.
I don't have configs to post, so can anyone spot any "red flags" or recommend obvious things to try for fixes?
Sorry for the lack of info. Appreciate all help in advance.
Regards,
Sean
Is you VPN tunnel up ? You can check the access-list is it getting any hit counters or is it allowed for Telnet traffic?
Thanks for the reply, CK.
The tunnel is up and telnet is good for 75% of the working day. Are there logs I can look at somewhere that might help me isolate the other 25%?
Do you have any syslog setup for logs may be rom logs youcan get from which side connection is discarded . source or destination as you mentioned earlier
I hope you will find some logs in log server
