ASA & FTP Problem
Feb 06, 2006 1 Replies
Hi
After changen from a PIX515 to an ASA5510, we can't use FTP in active mode from the inside network. There are no restrictions for inside users. Anyone her, that can explain why ?
BR
R.B.P.
You might want to switch back to the PIX:
Product: Cisco ASA 5500 Series Adaptive Security Appliances Version: Revision: Severity: 1-3 Features: view feature matrix | All Features Keywords: FTP Bug Status: Open,Fixed
Severity Bug ID & Title Found-in Version Fixed-in Version Status 1 CSCeg06076 Inbound ftp fails with nat 0 acl 7.0(81.152) 7.0(1), 7.0(0.60) Verified 2 CSCeg00860 XLATE: passive FTP fixup failures 7.0(0.57) Verified 2 CSCef68471 traceback:eip 0x005f8aec obj-f1/snp_api:_snp_inject_new_pkt+40 7.0(0.48) 7.0(1), 7.0(0.56) Verified 2 CSCeh07684 F1 traceback doing ftp uauth request with large connections 7.0(0.98) 7.0(1), 7.0(0.100) Verified 2 CSCeg77811 PERF:reset not sent to outbound ftp connections 7.0(0.89) Verified 2 CSCef65106 reload cannot fetch config file from ftp/tftp server 7.0(0.45) 7.0(1), 7.0(0.53) Verified 2 CSCeh08782 FTP traffic should to blocked when url-server is down with filter on 7.0(0.98) 7.0(1), 7.0(0.100) Verified 2 CSCeg53134 Deny ftp pages are permitted with websense filtering 7.0(81.204) 7.0(1), 7.0(0.81) Verified 2 CSCef47049 VPNFO: FTP transfer from MS server over VPN doesnt survive failover 7.0(0.41) Verified 2 CSCeg83476 Nessus scan causes F1 traceback 7.0(0.82) Verified 2 CSCeg08485 Commands in second ftp session not working when user already authent 7.0(0.60) 7.0(1), 7.0(0.69) Verified 2 CSCee46124 SSLC:FTP cut-through proxy carsh:file=fornax/tcp.c Thread uauth 7.0(0.9) Verified 2 CSCed66023 Failover and active FTP with PAT not working 1.0 7.0(0.1), 7.0(1),
7.0(0.56) Verified 2 CSCeg10719 IPv6:ASSERT ip.ip_version==IP_VERSION_4 failed in ipv6_types.h 94 7.0(0.60) 7.0(1), 7.0(0.61) Verified 2 CSCeg65024 Traceback in eip printf:_inet_ntop with fixup ftp strict configs 7.0(0.84) 7.0(1), 7.0(0.86) Verified 2 CSCeg31959 FTP failed with ipsec port select and tcp port with lt,gt,range oper 7.0(0.68) 7.0(1), 7.0(0.75) Verified 2 CSCef01697 webvpn port forwarding file upload vis secure ftp performance issues 7.0(81.51) 7.0(1), 7.0(0.93) Verified 2 CSCef22244 FTP Fixup:Passive FTP not working with Interface PAT. 7.0(0.32) 7.0(1), 7.0(0.50) Verified 2 CSCeg68094 VPN: TCP apps are not working on Benetton with IPComp, ping is fine 7.0(81.225) 7.0(1), 7.0(0.88) Verified 2 CSCef42257 TCP data requiring fragmentation is dropped by F1 7.0(0.38) 7.0(1), 7.0(0.60) Verified 2 CSCeh21779 FTP conn hang and crash on doing clear loc with A/S fover and IPS 7.0(0.102) 7.0(1), 7.0(0.104) Verified 2 CSCeg06228 FTP connections hang when uauth entry present 7.0(1), 7.0(0.60) Verified 2 CSCeg01897 Second ftp connection using previous uauth entry when timeout is 0 7.0(0.57) 7.0(1), 7.0(0.59) Verified 2 CSCeg01761 XLATE: active FTP fixup failures 7.0(0.57) Verified 2 CSCef77929 copy run to tftp fails in system context 7.0(0.50) Verified 2 CSCeg53394 Commands in second ftp session not working 7.0(0.80) 7.0(1), 7.0(0.83) Verified 2 CSCei28815 FIN-ACK Dropped even when the Sequence Number is within TCP Window 7.0(1) 7.0(2), 7.0(1.4) Verified 2 CSCeh06623 AAA: aaa hangs secondary FTP connection over VPN tunnel 7.0(1), 7.0(0.99) Verified 2 CSCeh81774 un-NATed ACK packets sent on outside interface 7.0(1) 7.0(2), 7.0(1.2), 7.0(3.1) Verified 2 CSCeh46289 AAA: Block is leaked during authorization 7.0(0.107) 7.0(1), 7.0(0.108), 7.0(3.1) Verified 2 CSCsc90826 PIX 7.0 getting the error %PIX-1-106021 when ip verify command enable 7.0(4) Assigned 2 CSCsc51939 Performance throughput problems through the PIX w/ http inspect enabled 7.0(2) Assigned 2 CSCsc58597 FTP pasv mode file transfer failure using VPN with CSC enabled 7.1(0.133) Verified 3 CSCsc94629 AIC FTP: inspect FTP commands are not applied during reload in Multiple 7.2(0.11) Assigned 3 CSCsc94646 AIC FTP: match not filetype doesnt work as desired in Multiple mode 7.2(0.16) Assigned 3 CSCed86480 Uninitialized variables in capture and FTP inspect 700.0 7.0(0.1), 7.0(1) Verified 3 CSCeg54198 550 message intermittent missing with ftp filtering and aaa authenti 7.0(0.80) Verified 3 CSCeg30227 logging ftp-bufferwrap seems to only have a 12 hour clock 7.0(0.60) 7.0(1), 7.0(0.81) Verified 3 CSCeh07577 FTP data session hangs when established command is configured 7.0(0.97) 7.0(1), 7.0(0.101) Verified 3 CSCee27520 Strict FTP obfuscates SYST reply - doesnt work with Netscape client 7.0 7.0(1), 7.0(0.12), 7.0(0.16) Verified 3 CSCef78134 Blocked FTP auth prompt different than PIX 6.3 7.0(0.121) Verified 3 CSCsc98248 WCCP service 60 native ftp is not working 7.103 Verified 3 CSCed95893 DIP - FTP mode command broken 7.0(80.211) 7.0(0.1), 7.0(1) Verified 3 CSCef33231 AAA:Authorzn failed message not displayed for FTP/HTTP sessions. 7.0(0.35) 7.0(1), 7.0(0.81) Verified 3 CSCeh12981 AAA:ftp data connection closed when uauth timeout set to 0 7.0(0.100) 7.0(1), 7.0(0.101) Verified 3 CSCeg85258 Second command in active ftp session not working 7.0(81.245) 7.0(1), 7.0(0.95) Verified 3 CSCef06167 IP audit FTP signatures need to enabled 7.0 7.0(1), 7.0(0.29) Verified 3 CSCeg86746 FTP filtering with Websense is not filtering 7.0(0.94) 7.0(1), 7.0(0.95) Verified 3 CSCeg07235 AAA must accept numeric value for protocol 7.0 7.0(1), 7.0(0.66) Verified 3 CSCeg55372 Service resetinbouund (and its default) does not behave as expected 7.0(0.75) 7.0(1), 7.0(0.88) Verified
