NS 5XP
Oct 24, 2007 2 Replies
dear guru, Cannot access internet out of the sudden, thinking this may be license limitation on my old NS box.
  1. Does the license limitation apply to concurrent users on my old NS?
  2. How can I check how many license has been used?
  3. How can I reset the license for temporary remedy? thx, Huang
There's no time limit on ScreenOS however there is a session limit (number of connections). You can "clear session" but this will drop everyone's connections. My guess is you have a real problem with your ISP.
alan
There *is* a user count limitation. You can "get license" to see how many IPs your license is for. This box is no longer supported, if you need more capability you should buy an SSG-5 or SSG-20.
