netgear FWG114P outbout rule problem
Mar 19, 2008 0 Replies
I've got a netgear FWG114P and I'm trying to configure a machine to do outbound HTTP only w/ the following two rules in this order.
I enable an HTTP rule w/ the action "ALLOW always" from 'any' LAN to 'any' WAN. Then in the DEFAULT rule it says 'any' service 'BLOCK always' from 'any' LAN to 'any' WAN.
Both rules are enabled.
Yet, when I try to get out, HTTP is blocked, but if I set the default to 'ALLOW always', then I can get through.
Shouldn't the config I put in be saying, allow all HTTP and block everything else in the listed order? Meaning, it matches the first rule and that's it if I'm doing HTTP?
