NAT Device Configuration
Feb 21, 2005 1 Replies
I decided to put in a NAT device to add extra security for my SBS2000 network with ISA. I have two nic cards installed in the server, the public nic using a static ip and the private nic using 10.0.0.2. I installed a Network Everywhere NR041 Cable/DSL router between my server and my DSL modem, set it in router mode, and assigned the WAN ip the ip I was using for my public nic on the server. I then changed the server public nic to 172.16.1.2 and set the Cable/DSL router LAN ip to
172.16.1.1.
So...
Internet-->DSL Modem-->Cable/DSL Router-->Server-->LAN
Router: Lan-172.16.1.1 ; Wan-***.***.***.*** ; DHCP Disabled Server: Private-10.0.0.2 ; Public(connected to router)-172.16.1.2
After making the changes I try to run ICW and while ICW is configuring Exchange server I keep getting the message: "The Internet Connection Wizard was interrupted because of an error or user intervention".... The fact that I have two non-routable ips assigned to my server nics didn't seem right to me.
Before I start tearing into the icwlog.txt file can anyone tell me if the router and server setup looks ok?
Any help would be greatly appreciated.
Kevin G
This may help
Jason
