Hi all,
I'm not quite sure if SocksCap is same as tunneling application such as HTTP Proxy or something like that or is it to be used in conjunction with the tunneling software. Could someone clarify, thanks!
Ben
SOCKS can forward general traffic, so it's more than a simple tunnel (it can dynamically add stuff to be forwarded, which most tunnels won't do). An HTTP proxy is not a tunneling application, though you could use a tunneling application to run a HTTP tunnel over it. (The proxy…
Read the full replyHi all,
Ben
An HTTP proxy is not a tunneling application, though you could use a tunneling application to run a HTTP tunnel over it. (The proxy itself does not build tunnels in the conventional sense of the word, after all.)
I don't know what SocksCap is, sorry!
Joachim
It is a small software package that allows non socks capable software to use socks proxies.
SocksCap? automatically enables Windows-based TCP and UDP networking client applications to traverse a SOCKS server. SocksCap intercepts the networking calls from WinSock applications and redirects them through the SOCKS server without modification to the orginal applications or to the operating system software or drivers.
