How to completely uninstall NIS 2002
Aug 17, 2007 3 Replies
Sebastian G.
> Please reply with hyperlink to procedure.. or specific instructions. Search for the NIS removal tool on ...
Have been reading about the uninstall routine downloadable from Symantec, but what about an older version like 2002? I'd like that whole mess removed down to the last registry entry. Please reply with hyperlink to procedure.. or specific instructions.
-G
Backup your data. Format. Reinstall.
cu
59cobalt
On Fri, 17 Aug 2007 12:06:50 +0200, "Sebastian G." brought the following to our attention:
Thanks.. found a NFP and NAV utility for v2002 and ran them. Routines left .log files on desktop.. and apparently few if any traces of Norton were found or removed. Guess the normal uninstalls worked ok.. and the Reg cleaners too!!
-G
