[HELP] Iptables - block multiconnection from the same ip
Nov 18, 2005 1 Replies
I need to block connections on port 23 (or other...) from an IP when it try to open more than one connection...
In other words the ip xxx.xxx.xxx.xxx might open only one telnet session at time...
I don't want 2 or more connection from the same ip... only one...
Is that possible using itables rules? Could you help me?
~oma
From the iptables manual page:
iptables -p tcp --syn --dport 23 -s xxx.xxx.xxx.xxx -m connlimit --connlimit-above 1 -j REJECT
