FTP Problem
Sep 24, 2005 4 Replies
Jump to replies (4)
Hi
I'm having difficulty uploading my website. I've been using WS_FTP without problem until I installed a Netgear DG834G ADSL Router.
Now I find I can upload very small files (up to about 3k). Anything larger, I get a message saying data connection closed, receive file ..... aborted.
The problem is clearly with my computer / router as I can email the files to work and upload them from there. Also, I have tried using Smart FTP and have the dame problem.
I would be grateful for any advice
Thanks
Hi
This is what the log says when I tried to send 5.5k. As you can see, the trtansmission was aborted.
connecting to 217.79.111.119:4902 Connected to 217.79.111.119 port 4902 LIST
150 Opening ASCII mode data connection for /bin/ls. Received 417 bytes in 0.1 secs, (40.00 Kbps), transfer succeeded 226-Maximum disk quota limited to 25600 Kbytes Used disk quota 1169 Kbytes, available 24430 Kbytes 226 Transfer complete. sending COT-CLEA.SCH as COT-CLEA.SCH (1 of 1) TYPE I 200 Type set to I. PASV 227 Entering Passive Mode (217,79,111,119,19,39) connecting to 217.79.111.119:4903
- - connecting to 217.79.111.119:4903 Connected to 217.79.111.119 port 4903 STOR COT-CLEA.SCH
150 Opening BINARY mode data connection for cot-clea.sch. Transmitted 5468 bytes in 0.1 secs, (530.00 Kbps), transfer succeeded 426-Maximum disk quota limited to 25600 Kbytes Used disk quota 1169 Kbytes, available 24430 Kbytes 426 Data connection closed, receive file cot-clea.sch aborted.
The problem may be related to this.
Jason
What does Netgear Support say?
Yours, VB.
