fanless 24 port gigabit switch
Nov 17, 2009 7 Replies
Jump to replies (7)
I'm currently using a Netgear JGS524 gigabit switch that works fine, but I'm trying to reduce fan noise in the office. I want to replace it with a fanless 24 port gigabit switch. The HP ProCurve 1400 looks like a good fit. Any comments on the HP 1400? Any other suggestions?
Best, Christopher
I don't have any experience with that switch, but since the ventor doesn't use a fan I believe you won't have any particular problem using it. Provided that there is as much space as possible among the devices.
Good luck!
Giorgos
What makes you think your questions have anything at all to do with firewalls?
cu
59cobalt
Good question. It was the best fit I could find that receives any traffic, but I'm open to suggestions.
Best, Christopher
Don't know about traffic, but you could try alt.comp.networking.routers or alt.comp.network.connectivity.
cu
59cobalt
Concerning traffic, alt.comp.network.connectivity would be just fine.
Giorgos
I don't know how difficult it might be to open the JGS524, but I do know that some of the newer fans are pretty quiet. You might be able to install a quieter fan.
bad idea you'll be voiding warranties, and a lot of enterprise switches have lifetime warranties (well HP has :D)
although this isn't an enterprise switch
