disabling checkpoint statefull inspection
Nov 02, 2005 10 Replies
Jump to replies (10)
Anyone know off hand if its possible to disable checkpoint statefull inspection for a particular requests only? i'm running into an issue where NFS packets are getting dropped because of checkpoints state table already has an established connection and the nfs protocol is sending a SYN to create a new connection.
from RFC-1813 nfsv3 The typical NFS version 3 protocol failure recovery model uses client time-out and retry to handle server crashes, network partitions, and lost server replies. A retried request is called a duplicate of the original.
Why do you want to use a firewall, if you let NFS through?
Yours, VB.
that's maybe not the answer to the question. i also run a checkpoint-cluster. this controlls traffic to/from internet. but also traffic on an other interface to our subsidiaries, which are reachable through a vpn managed by an isp.
so, why not allowing nfs through a fw in a private wan.
best regards hans
Because NFS is an invitation to everybody who wants to compromize your policies. If you let something inherent insecure through your filtering system like NFS, you can drop filtering, too, and you'll have just the same effect.
Yours, VB.
Am Thu, 03 Nov 2005 05:36:10 +0100 schrieb Volker Birk:
Come on, Volker, there are setups in which this is required.
What about different internal subnets with the NFS server located in one *internal* subnet and the clients in another with the checkpoint box between them?
Wolfgang
I cannot see that, really.
If you mean "security zone" with "subnet", then the security concept is b0rken. NFS is so unsecure, that it may not be allowed between zones.
Wolfgang, do you remember, that NFS is without any cryptography, and how authorization is done with NFS?
Yours, VB.
no, not everybody. this can be one point of view.
we filter between our subsidiaries. and we do this not, as we think we must protect our users from themselfe. we filter those ports, which are critical for virus and maleware attacks. lets say, we allow some uncritical ports and drop all others.
so we hope, a virus cannot propagate all over the corporate network immediatly. didn't see any microsoft-virus based on nfs. did you ?
best regards hans
Oh yes, of course. NFS is for sharing files, and file infecting viruses are very common in the Windows world.
Yours, VB.
While I agree that such a concept might be called broken such setups simply do exist in real life.
I agree but locations where circumstances that require such setups exist. The world is far from beeing ideal.
I'm well of aware of the risks of NFS.
Of course it is better to resign a network but there are cases where a redesign is hardly possible.
Wolfgang
Wolfgang Kueter wrote: [NFS through zones]
Yes. "Two things are infinite." And with the universe, he was unsure.
I disagree.
Yes.
Yours, VB.
Am Fri, 04 Nov 2005 12:16:55 +0100 schrieb Volker Birk:
You need only 5 lines to contradict yourself, respect.
Wolfgang
