Hi all
I am logging a pix515 to a syslog server. I would like to set the logging device-id but the pix will not take the command>?
I believe the syntax should be # logging device-id pixname
Does anyone know what I am doing wrong?
Thanks
You did not indicate your PIX software version. You need to be in configuration mode to enter the command -- the above makes it appear that you are in enable mode. In the syntax of logging device-id, 'hostname' is a literal keyword. Your three choices are: logging device-id…
Read the full replyHi all
Thanks
logging device-id hostname logging device-id ipaddress INTERFACENAME logging device-id string TEXT
where INTERFACENAME and TEXT are arbitrary, but everything else is literal.
