syslog through tunnel
Feb 11, 2005 3 Replies
Jump to replies (3)
Hello, I created a VPN Tunnel between a concentrator 3005 and PIX 501. I can't get the pix to syslog to a syslog server behind the concentrator through the VPN tunnel. The syslog server is logging events on the concentrator. The tunnel is up and hosts behind the PIX can ping hosts behind the concentrator. Here is my syslog configuration on the pix: access-list vpn permit ip 192.168.200.0 255.255.255.0 10.128.9.0
255.255.255.0 access-list vpn permit ip host 192.168.200.50 (local syslog ip) host
66.168.5.2 nat (inside) 0 access-list vpn logging on logging trap debugging logging facility 20
snmp-server snmp-server enable traps
I tried both logging configs logging host outside 192.168.200.50 snmp-server host outside 192.168.200.50 and logging host inside 192.168.200.50 snmp-server host inside 192.168.200.50
I also changed the logging host and snmp to the inside interface of the concentrator and cannot get the logging information
please help thanks
Given that you have the latest PIX 501 software, try configuring
management-access inside
on the PIX 501
f the above works it should also address your SNMP issue
