Troubleshooting site-to-site VPN with two PIX 501s
Jul 25, 2006 9 Replies
Jump to replies (9)
Troubleshooting site-to-site VPN with two PIX 501s open original image
I have a central office PIX 501 that currently runs independent site-to-site VPNs for around 5 remote offices, and I'm trying to add a
6th VPN. I'm using pre-shared keys for authentication.
Central office LAN is 172.16.1.0/16, remote office LAN is
172.20.6.0/24. When I try and pass interesting traffic over the VPN, the VPN LED on the PIX illuminates so it seems like a connection is actually made. However, the packets never get through -- pings and telnet attempts time out. I have even added a static route on a target machine in the 172.16.1.0 network.
What information could I please provide to help y'all debug this with me? Here is the important output from config term:
(central office)
ip address outside 64.sss.198.6 255.255.255.240 ip address inside 172.16.1.192 255.255.0.0 isakmp key ****** address 63.xxx.214.138 netmask 255.255.255.255 access-list nonat permit ip 172.16.1.0 255.255.255.0 172.20.6.0
255.255.255.0 access-list nonat permit ip 172.16.10.0 255.255.255.0 172.20.6.0
255.255.255.0 access-list nonat permit ip 172.16.11.0 255.255.255.0 172.20.6.0
255.255.255.0 access-list SPRINGVALE permit ip 172.16.1.0 255.255.255.0 172.20.6.0
255.255.255.0 access-list SPRINGVALE permit ip 172.16.10.0 255.255.255.0 172.20.6.0
255.255.255.0 access-list SPRINGVALE permit ip 172.16.11.0 255.255.255.0 172.20.6.0
255.255.255.0 crypto ipsec transform-set springvaleset esp-3des esp-md5-hmac crypto map site-vpn 6 ipsec-isakmp crypto map site-vpn 6 set peer 63.xxx.214.138 crypto map site-vpn 6 set transform-set springvaleset crypto map site-vpn 6 match address SPRINGVALE sysopt connection permit-ipsec global (outside) 1 interface nat (inside) 0 access-list nonat nat (inside) 1 0.0.0.0 0.0.0.0 0 5000 route outside 0.0.0.0 0.0.0.0 64.sss.198.1 1
(remote office)
ip address outside 63.xxx.214.138 255.255.255.0 ip address inside 172.20.6.191 255.255.255.0 access-list rcd_pph permit ip 172.20.6.0 255.255.255.0 172.16.0.0
255.255.0.0 global (outside) 1 interface nat (inside) 0 access-list rcd_pph nat (inside) 1 0.0.0.0 0.0.0.0 0 0 route outside 0.0.0.0 0.0.0.0 63.xxx.214.129 1 sysopt connection permit-ipsec crypto ipsec transform-set transrcd esp-3des esp-md5-hmac crypto map rcdmap 1 ipsec-isakmp crypto map rcdmap 1 match address rcd_pph crypto map rcdmap 1 set peer 64.sss.198.6 crypto map rcdmap 1 set transform-set transrcd crypto map rcdmap interface outside isakmp enable outside isakmp key q1w2e3r4 address 64.sss.198.6 netmask 255.255.255.255 isakmp identity address isakmp policy 1 authentication pre-share isakmp policy 1 encryption 3des isakmp policy 1 hash md5 isakmp policy 1 group 2 isakmp policy 1 lifetime 86400
Given that I have existing remote networks (e.g. 172.20.1.0/24,
172.20.2.0/24, etc) connecting to the central office I am quite baffled by what the problem is. When I try and ping across the VPN, here is the output from a combined "debug crypto {ipsec,isakmp,engine}" running on the remote office PIX:
ISAKMP (0): beginning Quick Mode exchange, M-ID of
1243172245:4a194d95IPSEC(key_engine): got a queue event... IPSEC(spi_response): getting spi 0x596bc730(1500235568) for SA from 64.sss.198.6 to 63.xxx.214.138 for prot 3
crypto_isakmp_process_block:src:64.sss.198.6, dest:63.xxx.214.138 spt:500 dpt:500 ISAKMP (0): processing NOTIFY payload 14 protocol 3 spi 1500235568, message ID = 1860390180 ISAKMP (0): deleting spi 818375513 message ID = 1243172245 return status is IKMP_NO_ERR_NO_TRANS6: ICMP echo-request from inside:172.20.6.1 to 172.16.1.30 ID=768 seq=22784 length=40
7: ICMP echo-request from inside:172.20.6.1 to 172.16.1.30 ID=768 seq=23040 length=40
8: ICMP echo-request from inside:172.20.6.1 to 172.16.1.30 ID=768 seq=23296 length=40 IPSEC(key_engine): request timer fired: count = 1, (identity) local= 63.xxx.214.138, remote= 64.sss.198.6, local_proxy= 172.20.6.0/255.255.255.0/0/0 (type=4), remote_proxy= 172.16.0.0/255.255.0.0/0/0 (type=4)
-31348343:fe21a989IPSEC(key_engine): got a queue event... IPSEC(spi_response): getting spi 0xa180df8c(2709577612) for SA from 64.sss.198.6 to 63.xxx.214.138 for prot 3
crypto_isakmp_process_block:src:64.sss.198.6, dest:63.xxx.214.138 spt:500 dpt:500 ISAKMP (0): processing NOTIFY payload 14 protocol 3 spi 2709577612, message ID = 1859416444 ISAKMP (0): deleting spi 2363457697 message ID = 4263618953 return status is IKMP_NO_ERR_NO_TRANS9: ICMP echo-request from inside:172.20.6.1 to 172.16.1.30 ID=768 seq=23552 length=40
10: ICMP echo-request from inside:172.20.6.1 to 172.16.1.30 ID=768 seq=23808 length=40
11: ICMP echo-request from inside:172.20.6.1 to 172.16.1.30 ID=768 seq=24064 length=40
12: ICMP echo-request from inside:172.20.6.1 to 172.16.1.30 ID=768 seq=24320 length=40
13: ICMP echo-request from inside:172.20.6.1 to 172.16.1.30 ID=768 seq=24576 length=40
14: ICMP echo-request from inside:172.20.6.1 to 172.16.1.30 ID=768 seq=24832 length=40 IPSEC(key_engine): request timer fired: count = 2, (identity) local= 63.xxx.214.138, remote= 64.sss.198.6, local_proxy= 172.20.6.0/255.255.255.0/0/0 (type=4), remote_proxy= 172.16.0.0/255.255.0.0/0/0 (type=4)
15: ICMP echo-request from inside:172.20.6.1 to 172.16.1.30 ID=768 seq=25088 length=40
And so on and so on. It's interesting that I never see what is a "fatal" error; or perhaps I'm not interpreting the output correctly? TIA for any & all help!
Chris
Hi Chris,
Possibly your Cisco PIX 501 license may only allow 10 concurrent users.
If you require more than 10 users to have access through the PIX 501 Firewall at one time, perform these steps:
  1. Purchase a 50-user license upgrade.
The part number is: PIX-501-SW-10-50
For a Price Quote call Reggie Grant Toll Free 877-549-2680 or
828-277-7272:
Additionally, you may wish to investigate Cisco PIX Security Appliance Licensing:
  1. If you have already purchased a license, send an email to:
licensing *at* cisco.com
Include serial number, purchase information, PIX Firewall Software version and model and what needs to be added on the activation key.
To get the PIX serial number, PIX software version and PIX model number, issue the show version command.
A show version command also tells you what type of license the PIX Firewall is running, either R ( restricted ) or UR ( unrestricted ).
Hope this helps.
Brad Reese BradReese.Com - Refurbished Cisco PIX Firewall Guide
Trolling through a support groups to drum up business is not generally accepted, that is what advertising is for.
VPN peers: 10*
  • Maximum number of simultaneous site-to-site or remote access IKE Security Association (SAs) supported
Since this is his 6th IPSec connection there is no license issue.
When you have the remote unit up, what does "show crypto ipsec sa" show? It is kind of late where I am so I am going to look at this tomorrow, but in the meantime, I know this is a stupid question, but do you have ICMP allowed through the interfaces? For example, if you do not have ICMP allowed for the LAN address at the remote it will of course fail in pinging. The reason I say this is this just came up about 2 days ago. Someone freeked out because they thought their VPN did not work, when in fact it was only that pinging was disable from their remote network.
When setting up the 6th site, did you recreate from scratch or copy an existing config editing the specifics like IP address?
wrote: > Hi Chris, >
Does the "10-user limit" work off of 10 separate VPN connections with N users connected to each (i.e. the actual amount of *users* is irrelevant), or can you have N connections so longer as the number of users < 10?
I didn't explicitly allow (or deny) ICMP... I am only using ACLs to differentiate between traffic that should go across the VPN, and traffic that shouldn't. Perhaps I have done this incorrectly? Either way, neither ping nor telnet across the VPN worked; hence I didn't think it was just an ICMP issue (though I could be wrong!)
The latter, I just changed what I thought the connection would need. I'm most confused that the VPN LED on the PIX illuminates, indicating that there *is* a connection; just that I can't get the connection to do what I want it to.
Chris
I forgot to look something up... the central office PIX actually has an unlimited license, thus it obviously doesn't care how many PIXes are connecting to it. The remote PIX has a 10-user license, but that's 9 more users than I have.
CO PIX:
Licensed Features: Failover: Disabled VPN-DES: Enabled VPN-3DES-AES: Enabled Maximum Physical Interfaces: 2 Maximum Interfaces: 2 Cut-through Proxy: Enabled Guards: Enabled URL-filtering: Enabled Inside Hosts: 50 Throughput: Unlimited IKE peers: 10
Chris
He hasn't happened to mention which PIX OS version he is running, and the config extracts did not happen to include anything characteristic of one PIX version but not another.
On the 501, the peer limit did not become 10 until PIX 6.3(1); it is 5 in PIX 6.1 and PIX 6.2.
One of the PIXes is running 6.3(4), the other is running 6.3(3).
Chris
Number of comp.dcom.sys.cisco postings presenting useful information attempting to help people:
Brad Reese ( snipped-for-privacy@bradreese.com, snipped-for-privacy@bradreese.com, snipped-for-privacy@alliancedatacom.com): more than 1100
John Doe ( snipped-for-privacy@hotmail.com, snipped-for-privacy@are.bad.com, snipped-for-privacy@he.hinet.hr, snipped-for-privacy@eos.hitc.com, snipped-for-privacy@jd.com, snipped-for-privacy@dev.null, snipped-for-privacy@mouse.org, snipped-for-privacy@ftc.gov AKA Bryan Martin snipped-for-privacy@ahwayside.com, et al.): less than 40
I've never seen Brad troll *this* newsgroup (alt.marketing.online.ebay perhaps, but not comp.dcom.sys.cisco.) I have seen him attempting to help people many times. He perhaps does not always read the problem as deeply as might be desirable, and tends to post documentation references instead of his own explanations -- but he does *try* to help people.
Helping is one thing all together different than trying to make a unnecessary sale. At the very least lets work out Chris's problem first and foremost. If there was a need to upgrade the license then maybe options could be discussed. I just take this from the perspective of being a reseller myself (I am here to learn and help out if I can). Maybe I was a little harsh, and for that I apologize, but first and foremost let us deal with the problem at hand and worry about upgrades and such later.
I would also add for convenience in testing "icmp permit any inside"
Also, does "show crypto sa" clearly show that the SA's are established? I believe though the problem lies more with NAT, I just do not really see where the problem lies, all the access lists look fine.
I just had issues the other day where using FreeBSD to Cisco will create a tunnel, but SAs are not established. So the PIX would show a connection, yet no traffic can traverse the VPN.
Try the command on both central and remote to see what happens. Also, have you tried connection in reverse, meaning from central to remote?
Here is an example of what you should see with "show crypto sa":
interface: outside Crypto map tag: dyn-map, local addr. 6x.xxx.xxx.xx local ident (addr/mask/prot/port): (192.168.1.0/255.255.255.0/0/0) remote ident (addr/mask/prot/port): (192.168.2.0/255.255.255.0/0/0) current_peer: 72.135.40.162:500 PERMIT, flags={} #pkts encaps: 40276, #pkts encrypt: 40276, #pkts digest 40276 #pkts decaps: 33478, #pkts decrypt: 33478, #pkts verify 33478 #pkts compressed: 0, #pkts decompressed: 0 #pkts not compressed: 0, #pkts compr. failed: 0, #pkts decompress failed: 0 #send errors 0, #recv errors 0 local crypto endpt.: 6x.xxx.xxx.xx, remote crypto endpt.:
7x.xxx.xxx.xx path mtu 1500, ipsec overhead 72, media mtu 1500 current outbound spi: 5f8992c2 inbound esp sas: spi: 0x62de9891(1658755217) transform: esp-aes-256 esp-md5-hmac , in use settings ={Tunnel, } slot: 0, conn id: 4, crypto map: dyn-map sa timing: remaining key lifetime (k/sec): (4600201/26885) IV size: 16 bytes replay detection support: Y inbound ah sas: inbound pcp sas: outbound esp sas: spi: 0x5f8992c2(1602851522) transform: esp-aes-256 esp-md5-hmac , in use settings ={Tunnel, } slot: 0, conn id: 3, crypto map: dyn-map sa timing: remaining key lifetime (k/sec): (4599036/26885) IV size: 16 bytes replay detection support: Y outbound ah sas: outbound pcp sas:
Also, have you brought this to the discussi> I have a central office PIX 501 that currently runs independent
