What does the X stand for in TX- FX
Feb 11, 2005 6 Replies
Rich Seifert
It doesn't "stand for" anything. When we were developing the 100 Mb/s Ethernet standard, a proposal was initially presented for an encoding scheme that supported both twisted pair and fiber. To facilitate discussion, it was called "100BASE-X", where the "X" was a placeholder…
It doesn't "stand for" anything. When we were developing the 100 Mb/s Ethernet standard, a proposal was initially presented for an encoding scheme that supported both twisted pair and fiber. To facilitate discussion, it was called "100BASE-X", where the "X" was a placeholder for whatever medium would ultimately be used. The symbolism stuck and we kept the "X" designation to indicate the use of 4B/5B block encoding;
-TX meant that coding on twisted pair, and -FX meant that encoding used on fiber.
-- Rich Seifert Networks and Communications Consulting 21885 Bear Creek Way (408) 395-5700 Los Gatos, CA 95033 (408) 228-0803 FAX
Send replies to: usenet at richseifert dot com
Total coincidence. Remember, ALL of the ANSI computer technology standards have an "X3" designation, from X3.1 (Synchronous Modem Signaling Rate standard) to X3.332 (SCSI-3) and everything in between.
Hello can anyone tell me what the X indicates in a TX or FX cable.
Thanks,
Justin.
So it's a coincidence then that the ANSI standards which these port types are based on, also have an X in their name? If I'm not mistaken, the PCS of
100BASE-X is based on the X3.263 standard (FDDI), and the PCS of 1000BASE-X is based on the X3.230 standard (Fibre Channel).
Michael (remove filter from email address)
Maybe so, but not all the Ethernet port types reference ANSI X-series standards! ;-) Anyway, thanks for clearing up this little mistery about Ethernet.
Note also that 10PASS-TS references American National Standard T1.424, but the T's in both names have nothing to with each other either!
Hello Rich,
RHS> Remember, ALL of the ANSI computer technology > standards have an "X3" designation, from X3.1 > (Synchronous Modem Signaling Rate standard) to X3.332 > (SCSI-3) and everything in between.
I would like a modem that runs as fast as SCSI ...over a domestic analogue telephone line. :-)
- Andy Ball
