Travelling PC - Need Help!
Sep 08, 2004 2 Replies
I need to stablish a non wired network connection between 2 PC. One of
them is a laptop mounted in a vehicle moving at an average speed of 35
miles per hour and I need the necesary bandwith to stream Low res
video.
I need to cover 65 miles and I can install as many Acces points as
necesary (obiously if access point are the solution )
The major problem here is the speed at the vehicle is moving.
Is Wi-Fi the solution to this connectivity problem? Some of you know how can I solve this?
Thanks id advance for your aswer.
Federico.-
I guess Wi-Fi won't do ( too many AP and too fast ). What's called WiMAX could do, as well as UMTS.
Arnold
  • Arnold Nipper :
I hope you are factoring in the damage caused to a spinning hard-disk due to the vibrations/jerks caused by a moving vehicle.
Why not hook the laptop to the data port of a mobile phone?
