Linksys BEFW11S4 ver.3: Upgrade firmware?
Mar 29, 2005 2 Replies
BradReeseCom
Hi Eugene, You may find the Linksys Knowledge Base helpful: Brad Reese Cisco Resource Center Toll Free: 877-549-2680 International: 828-277-7272=20 Website:
Linksys BEFW11S4 ver.3: Upgrade firmware? open original image
My Linksys Wireles / 4-port Router shows "1.45z, Feb 28 2003" firmware version. According to the web-site the latest for this model is
1.45.10 (dated 4/15/2004), which is one step up.
I'm experiencing connection interruptions that are especially annoying when I'm using VPN and quickly run out of available sessions.
I'm not sure whether the improvements made between the two versions could resolve my problem
). Any opinions?
TIA, Eugene
Hi Eugene,
Sincerely,
Brad Reese BradReese.Com=AE Cisco Resource Center Toll Free: 877-549-2680 International: 828-277-7272=20 Website:
Brad,
While I see "Recommended Firmware Upgrade for the BEFW11S4 Version 4" document there I found no similar guidelines for Version 3.
Have I missed something?
