I two VLANs serving the same subnet. One VLAN has 802.1Q tagging devices attached to it, the other has untagged devices attached to it. (I can't do this with tagged/untagged ports on the same VLAN for valid reasons, thought that would be the sane way). Can I bridge the VLANs together somehow? I'm having difficulty doing so with the router serving the switch.
I've successfully "bridged" them using a patch cable joining untagged ports of the two VLANs, but I have to sacrifice two ports to do this.
Thanks,
