Wireless Control System, Radius, and controller configuration
Aug 13, 2007 6 Replies
Jump to replies (6)
We're just starting with the cisco Wireless Control System. We'd like to utilize it as follows:
User logs in to the login.html bundle. The bundle passes off username/ password to our wireless radius server, which returns success/fail and, if success, the SSID the user should be assigned to, if fail, the "guest" SSID.
How can we configure the controller's radius client to accept the SSID for the user and the user's ID, so that the user can associate with the access point geographically appropriate for the user?
Thank you!
~ We're just starting with the cisco Wireless Control System. We'd like ~ to utilize it as follows: ~ ~ User logs in to the login.html bundle. The bundle passes off username/ ~ password to our wireless radius ~ server, which returns success/fail and, if success, the SSID the user ~ should be assigned to, if fail, the ~ "guest" SSID. ~ ~ How can we configure the controller's radius client to accept the SSID ~ for the user and the user's ID, so that the user can associate with ~ the access point geographically appropriate for the user? ~ ~ Thank you!
This isn't behavior that you can control from the infrastructure side - it's up to the client device to decide which SSID it will try to associate to, and which AP within that SSID to use.
Aaron
Thanks, Aaron! Looks like cisco document ID 71683 tells me what I needed to know!
Hi there,
Im sysadmin for 6-7 years with big experience in radius in general, also made my own radius + oracle + wifi + wired solution so if you have any questions, i have some free time for few days so you can contact me on mail.
Damir
Hvala, Damire!
Do you have any Perl code that stuffs a buffer with both the access- accept and VLAN attributes, along the lines of:
my $resp = new RADIUS::Packet $d; $resp->set_code('Access-Accept'); $resp->set_attr('Tunnel-Type','VLAN'); $resp->set_attr('Tunnel-Medium-Type','802'); $resp->set_attr('Tunnel-Private-Group',"123");
my $respdat = auth_resp($resp->pack, "mysecret");
Hvala mnogo!
Is this maybe Radiator radius server we're talking about? Whatever it is I suggest you do the following Make realm or handler or anything else that will filter your specific group of users you're trying to handle and
do
AddToReply Tunnel-Type = VLAN, \\ Tunnel-Medium-Type = 802, Tunnel-Private-group = 123
If you give me your specific radiator implementation i can give you more specific answer. Also if you are planning to use database for all of your authentication then its similar implementation,but i can explain.
Damir
No. It'll be FreeRadius on Linux.
The "hook" Free Radius gives us is rlm_perl and that's fine. I can deal with the db just fine.
