PIX 501 PPTP VPN RADIUS authentication problem
Aug 02, 2005 3 Replies
Jump to replies (3)
I am having a problem getting RADIUS authentication to work with a CISCO PIX 501 (version 6.3(4)).
My network is configured like this:
RADIUS Server PIX NETGEAR DG834 Router DSL Provider
The PIX'S External_IF is connected to the routers LAN port and are on the same IP network. The router has one Public IP address assigned to it's external_IF. Everything else works fine with my configuration (web, dns, etc...) but incoming VPN connections fail. An outside user is able to connect to the PIX but I believe authentication fails. When at the PIX console I can see an outside user connect but shortly later they will be disconnected. The users see a windows dialog saying "authenticating username and password" but that eventually fails. Now I am able to get everything working in a test enviroment if I remove the router from the picture and directly connect a simulated external client directly to the PIX's outside interface. Authentication and everything works fine. I know there are issues with PAT and PPTP so my guess is that the extra NATing (or PATing in PIX terms) the router is doing with the PIX's outside IF is causing the problems. Is there a workaround or does anyone see any problems with the way I am doing things. Hopefully I included all the info you need.
Below are samples of my PIX's config:
PIX Version 6.3(4) interface ethernet0 auto interface ethernet1 100full nameif ethernet0 outside security0 nameif ethernet1 inside security100
hostname xxxxxx domain-name xxxx.local fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69
access-list nat0-acl permit ip any 192.168.100.0 255.255.255.0
pager lines 10 icmp deny any outside mtu outside 1500 mtu inside 1500 ip address outside 192.168.1.1 255.255.255.0 ip address inside 192.168.100.3 255.255.255.0 ip audit info action alarm ip audit attack action alarm ip local pool pptp-pool 192.168.100.208-192.168.100.240 pdm logging informational 100 pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 0 access-list nat0-acl nat (inside) 1 0.0.0.0 0.0.0.0 0 0 static (inside,outside) tcp interface smtp server3 smtp netmask
255.255.255.255 0 0 access-group acl-outside-if in interface outside access-group acl-inside-if in interface inside route outside 0.0.0.0 0.0.0.0 192.168.1.4 1 timeout xlate 0:05:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server RADIUS (inside) host server3 xxxxxxxx timeout 10 aaa-server LOCAL protocol local aaa-server LOCAL protocol local ntp server server3 source inside http server enable http 192.168.100.0 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable sysopt connection permit-pptp telnet timeout 5 console timeout 0 vpdn group pptp-group accept dialin pptp vpdn group pptp-group ppp authentication mschap vpdn group pptp-group ppp encryption mppe auto required vpdn group pptp-group client configuration address local pptp-pool vpdn group pptp-group client configuration dns server3 vpdn group pptp-group client configuration wins server3 vpdn group pptp-group client authentication aaa RADIUS vpdn group pptp-group client accounting RADIUS vpdn group pptp-group pptp echo 60 vpdn enable outside terminal width 80 : end
I suppose it is not possible to hook your PIX up to the DSL provider? That would certainly make things easier. If I recall, PIX OS 6.3(4) does provide support for PPPoE. (I could be mistaken on that point.)
Have you forwarded TCP port 1723 through the NetGear to the PIX? This is the PPTP control channel and has to be passed through. I'm not familiar with that particular model of NetGear, but you may also need to enable "VPN passthrough" or similar in order for it to work. Some models refer to a "DMZ host," which you could also use to point to the PIX.
HTH.
I dont think running PPPoE on my PIX is possible because I am using my PIX as PPTP server also and the two dont jive from what I have researched.
As far as my router goes. I have a rule set to forward all traffic to the PIX, so port 1723 should be included. I havnt tried putting the PIX on the DMZ port so I will have to try that. I see a setting on the NetGear router that allows you to disable nating, I am not sure what affect this will have on the PIX though.
Thanks for the replys
In article , Scott Lowe wrote: :If I recall, PIX OS 6.3(4) :does provide support for PPPoE. (I could be mistaken on that point.)
Yes, PPPoE support was added somewhere around PIX 6.2.
