Why does my 506 keeps deny vpn-connections.
Mar 27, 2006 6 Replies
Most relevant reply
Walter Roberson
connection denied from 62.60.14.78/61510 to 62.60.14.70/25 flags SYN on interface outside Ah, somewhere along the way a line got dropped: access-group adgang in interface outside
Hi I am kind of new to Cisco and PIX=B4s. So I have the following problem. The vpn-clients cannot connect. According to the log is because the ACL "adgang".
What is wrong with the following config.
Hope that there is help out here.
Yours Erik
PIX Version 6.3(5) interface ethernet0 auto interface ethernet1 auto nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password 8Ry2YjIyt7RRXU24 encrypted passwd 2KFQnbNIdI.2KYOU encrypted hostname pixfirewall domain-name ciscopix.com fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names access-list inside_outbound_nat0_acl permit ip any 192.168.3.96
255.255.255.240 access-list outside_cryptomap_dyn_20 permit ip any 192.168.3.96
255.255.255.240 access-list outside_cryptomap_dyn_40 permit ip any 192.168.3.96
255.255.255.240 access-list adgang permit icmp any any access-list adgang permit tcp any host 62.60.14.70 eq smtp pager lines 24 mtu outside 1500 mtu inside 1500 ip address outside 62.60.14.70 255.255.255.240 ip address inside 192.168.3.1 255.255.255.0 ip audit info action alarm ip audit attack action alarm ip local pool vpnpool 192.168.3.100-192.168.3.110 pdm location 192.168.3.5 255.255.255.255 inside pdm logging informational 100 pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 0 access-list inside_outbound_nat0_acl nat (inside) 1 0.0.0.0 0.0.0.0 0 0 static (inside,outside) 62.60.14.70 192.168.3.5 netmask 255.255.255.255
0 0 access-group adgang in interface outside route outside 0.0.0.0 0.0.0.0 62.60.14.65 1 timeout xlate 0:05:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout sip-disconnect 0:02:00 sip-invite 0:03:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local http server enable http 192.168.3.0 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable sysopt connection permit-ipsec crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20 crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5 crypto dynamic-map outside_dyn_map 40 match address outside_cryptomap_dyn_40 crypto dynamic-map outside_dyn_map 40 set transform-set ESP-3DES-MD5 crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map crypto map outside_map client authentication LOCAL crypto map outside_map interface outside isakmp enable outside isakmp policy 20 authentication pre-share isakmp policy 20 encryption 3des isakmp policy 20 hash md5 isakmp policy 20 group 2 isakmp policy 20 lifetime 86400 vpngroup aam address-pool vpnpool vpngroup aam dns-server 192.168.3.5 vpngroup aam idle-time 1800 vpngroup aam password ******** telnet 192.168.3.0 255.255.255.0 inside telnet timeout 5 ssh timeout 5 console timeout 0 dhcpd address 192.168.3.2-192.168.3.254 inside dhcpd lease 3600 dhcpd ping_timeout 750 dhcpd auto_config outside dhcpd enable inside username eriklarsen password qE.UgiY71n5gFZpU encrypted privilege 15 terminal width 80 Cryptochecksum:a2ba207bd73bb6944b63227ed4160f71 : end
That line would allow the VPN clients to send icmp.
That line won't work. When the ip address named in an ACL is the IP address of an interface, instead of using 'host' followed by the IP, you need to use 'interface' followed by the interface name.
access-list adgang permit tcp any interface outside eq smtp
That line says that the interface ACL should be ignored for all IPSec packets, so that adgang ACL should not even be touched -- not unless the packets aren't going throug the VPN for some reason.
That won't work either. When an interface address appears in a static statement, you need to use the keyword 'interface' instead of the address:
static (inside,outside) interface 192.168.3.5 netmask 255.255.255.255 0 0
But then there is the additional problem that you cannot static the entire outside interface IP to an inside IP: you can static a public IP *other* than the interface IP:
static (inside,outside) 62.60.14.71 192.168.3.5 netmask 255.255.255.255 0 0
or you can static by port:
static (inside,outside) tcp interface smtp 192.168.3.5 smtp netmask
255.255.255.255 0 0
Your ip pool must not be in the same subnet as your inside addresses, or else the PIX will not be able to route the packets back to the VPN properly. Fixing this will require changes to several other statements.
Those two ACLs have the same content, so the policy 40 entry is redundant.
And notice you overlapped the dhcp pool with the vpn address pool. That's not going to matter once you fix the vpn address pool.
But also notice that you overlapped your dhcp pool with the IP of your server 192.168.3.5 . That's going to require fixing the dhcpd pool.
Hi Walter
I am getting there. Thanks for your quick help.
There only one remaining problem. Port 25 is not open for inbound mail, and I can=B4t figurer out why.
Could you give me some advise. The new config is as follows:
: PIX Version 6.3(5) interface ethernet0 auto interface ethernet1 auto nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password 8Ry2YjIyt7RRXU24 encrypted passwd 2KFQnbNIdI.2KYOU encrypted hostname pixfirewall domain-name ciscopix.com fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names access-list inside_outbound_nat0_acl permit ip any 192.168.30.0
255.255.255.192 access-list outside_cryptomap_dyn_20 permit ip any 192.168.30.0 255.255.255.192 access-list adgang permit tcp any interface outside eq smtp pager lines 24 mtu outside 1500 mtu inside 1500 ip address outside 62.60.14.70 255.255.255.240 ip address inside 192.168.3.1 255.255.255.0 ip audit info action alarm ip audit attack action alarm ip local pool aam 192.168.30.1-192.168.30.50 pdm logging informational 100 pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 0 access-list inside_outbound_nat0_acl nat (inside) 1 0.0.0.0 0.0.0.0 0 0 static (inside,outside) tcp interface smtp 192.168.3.5 smtp netmask 255.255.255.255 0 0 route outside 0.0.0.0 0.0.0.0 80.160.214.65 1 timeout xlate 0:05:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout sip-disconnect 0:02:00 sip-invite 0:03:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local http server enable http 192.168.3.0 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable sysopt connection permit-ipsec crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20 crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5 crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map crypto map outside_map client authentication LOCAL crypto map outside_map interface outside isakmp enable outside isakmp policy 20 authentication pre-share isakmp policy 20 encryption 3des isakmp policy 20 hash md5 isakmp policy 20 group 2 isakmp policy 20 lifetime 86400 vpngroup aam address-pool aam vpngroup aam dns-server 192.168.3.5 192.168.3.6 vpngroup aam wins-server 192.168.3.5 192.168.3.6 vpngroup aam default-domain aa-m vpngroup aam idle-time 1800 vpngroup aam password ******** telnet timeout 5 ssh timeout 5 console timeout 0 dhcpd address 192.168.3.2-192.168.3.254 inside dhcpd lease 3600 dhcpd ping_timeout 750 dhcpd auto_config outside username eriklarsen password 4OeqnkNPba5Vjnga encrypted privilege 15 terminal width 80 Cryptochecksum:ecfd64bf36d2c96afe0d253abe516f4e : end
You still have the overlap in the dhcp pool -- notice that it includes 192.168.3.5 [your server] in the IP range. That could result in two hosts ending up with the same IP address.
Once you fix that, I suggest you turn on logging and see what message is produced when you try the connection.
logging on logging timestamp logging buffered debugging
Once that is configured, "show log" to see the last 10 or so messages.
Once you have resolved the issue, you will probably want to change "logging buffered" from "debugging" to "notifications" so that only more important messages are recorded into the in-memory log. It would be a good idea, though, to
logging trap debugging logging host inside 192.168.3.SOMETHING
and set up a syslog server on 192.168.3.SOMETHING . If you don't have a handy Unix host, then the Windows "Kiwi" syslog server is okay in the free version and supposedly fairly good in the paid version.
Hi again
Walter, the syslog server gives the following line:
03-29-2006 19:43:39 Local4.Critical 192.168.3.1 %PIX-2-106001: Inbound TCP connection denied from 62.60.14.78/61510 to 62.60.14.70/25 flags SYN on interface outside
And the PDM complains about not being able to understand the following line:
So, it seems that the problem is the access-list.
A inside telnet on port 25 gives a normal reply from the mail-server.
yeps, that=B4s it.
Thank you so much for your help, walter
