CISCO PIX 506E REMOTE TO SITE VPN PROBLEM
May 21, 2007 0 Replies
Dear All,
I tried all but, i cannot connect to pix with cisco vpn client.
I would like to access to my network without any limitation with cisco vpn client. Please help me about it.
: Saved PIX Version 6.3(5) interface ethernet0 auto interface ethernet1 auto nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password xxxxxxxxxxxxxxx encrypted passwd xxxxxxxxxxxxxx encrypted hostname gw domain-name xxxxxx.com fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol icmp error fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names name 192.168.1.1 CS access-list outside_access_in permit ip interface outside interface inside access-list outside_access_in permit ip interface outside host
192.168.2.249 access-list outside_access_in permit ip 192.168.2.0 255.255.255.0 any access-list outside_access_in permit ip 192.168.2.224 255.255.255.224 interface inside access-list outside_access_in permit ip 192.168.3.0 255.255.255.224 any access-list outside_access_in permit tcp 192.168.3.0 255.255.255.224 any access-list outside_access_in permit udp 192.168.3.0 255.255.255.224 any access-list outside_access_in permit icmp 192.168.3.0 255.255.255.224 any access-list inside_outbound_nat0_acl permit ip 192.168.2.0
255.255.255.0 192.168.2.224 255.255.255.224 access-list inside_outbound_nat0_acl permit ip any 192.168.3.0
255.255.255.224 access-list inside_access_in permit ip any any access-list outside_authentication_LOCAL permit tcp 192.168.3.0
255.255.255.224 any access-list outside_cryptomap_dyn_60 deny ip any 192.168.3.0
255.255.255.224 pager lines 24 mtu outside 1500 mtu inside 1500 ip address outside pppoe setroute ip address inside 192.168.2.249 255.255.255.0 ip audit info action alarm ip audit attack action alarm ip audit signature 2000 disable ip audit signature 2004 disable ip local pool ttcc1 192.168.3.10-192.168.3.25 pdm location 0.0.0.0 255.255.255.255 outside pdm location 192.168.2.4 255.255.255.255 inside pdm location 192.168.2.5 255.255.255.255 inside pdm location 0.0.0.0 255.255.255.255 inside pdm location 81.214.120.188 255.255.255.255 outside pdm location 192.168.2.160 255.255.255.240 outside pdm location 192.168.2.192 255.255.255.224 outside pdm location CS 255.255.255.255 inside pdm location 192.168.2.0 255.255.255.252 inside pdm location 192.168.3.0 255.255.255.224 outside pdm location 192.168.2.0 255.255.255.0 outside pdm location 192.168.2.1 255.255.255.255 inside pdm location 192.168.2.224 255.255.255.224 outside pdm logging informational 100 pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 0 access-list inside_outbound_nat0_acl nat (inside) 0 192.168.2.249 255.255.255.255 0 0 nat (inside) 1 0.0.0.0 0.0.0.0 0 0 access-group outside_access_in in interface outside access-group inside_access_in in interface inside timeout xlate 0:05:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout sip-disconnect 0:02:00 sip-invite 0:03:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local aaa authentication match outside_authentication_LOCAL outside LOCAL http server enable http 0.0.0.0 0.0.0.0 outside http 192.168.2.0 255.255.255.0 inside http 192.168.2.249 255.255.255.255 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps no floodguard enable sysopt connection permit-ipsec sysopt connection permit-pptp sysopt connection permit-l2tp crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac crypto dynamic-map outside_dyn_map 60 match address outside_cryptomap_dyn_60 crypto dynamic-map outside_dyn_map 60 set transform-set ESP-3DES-MD5 crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map crypto map outside_map client authentication LOCAL crypto map outside_map interface outside isakmp enable outside isakmp identity address isakmp policy 20 authentication pre-share isakmp policy 20 encryption 3des isakmp policy 20 hash md5 isakmp policy 20 group 2 isakmp policy 20 lifetime 86400 vpngroup ttcc address-pool ttcc1 vpngroup ttcc idle-time 1800 vpngroup ttcc password ******** telnet 81.215.1XX.24 255.255.255.255 outside telnet 0.0.0.0 0.0.0.0 outside telnet 192.168.2.0 255.255.255.0 inside telnet 192.168.2.249 255.255.255.255 inside telnet timeout 60 ssh 0.0.0.0 0.0.0.0 outside ssh 0.0.0.0 255.255.255.255 inside ssh 192.168.2.249 255.255.255.255 inside ssh timeout 5 management-access outside console timeout 60 vpdn group pppoe_group request dialout pppoe vpdn group pppoe_group localname XXX@ttnet vpdn group pppoe_group ppp authentication pap vpdn username XXX@ttnet password XXXXXXX store-local dhcpd address 192.168.2.190-192.168.2.230 inside dhcpd dns 212.57.1.7 62.248.113.53 dhcpd lease 3600 dhcpd ping_timeout 750 dhcpd domain xxxx.com dhcpd auto_config outside dhcpd enable inside username ttadmin password xxxxxxxxxxx encrypted privilege 15 terminal width 80 Cryptochecksum:3xxxxxxxxxxxxxxxxxxxxxxx
