VRRP between VPN Concentrators
Apr 20, 2005 0 Replies
I have 2 VPN Concentrators at 2 different geographic locations. Both these locations are connected with a P-to-P link and share the LAN on the private side. However, the public internet access at both these locations is through two different ISPs on the ISP specific IP Space.
Can I run VRRP between these concentrators, and use them as hot standby for each other? I'm specifically concerned if I can run VRRP on the public interface, and if so, which of the two ISP IP address would I be able to use as Virtual IP address for both the public interfaces.
Thanks for help!
