Port Block
Apr 21, 2005 0 Replies
Hello All
I have been able to recover my 827H(corrupt ios- 15apr2005). The version of the IOS is newer than was previously used. The router is now fully functional except for what looks like a block of port 8080 when accessing 172.27.1.91, 172.27.1.86, 172.27.1.87 & port 80 on
10.125.50.80. I am using the configs that worked prior to my little fiasco. I can successfully ping these addresses but cannot telnet on
8080. Can some one explain where I have gone wrong.
Thanks in advance
alain
clock timezone ACST 9 30 ip subnet-zero no ip source-route ip domain-name internode.on.net ip name-server 192.231.203.2 ip name-server 192.231.203.3 ! crypto isakmp policy 10 hash md5 authentication pre-share group 2 crypto isakmp key xxxxx address 202.12.184.137 ! crypto ipsec transform-set insnettrans esp-3des esp-md5-hmac ! crypto map insnetvpn 10 ipsec-isakmp set peer 202.12.184.137 set transform-set insnettrans match address 101 ! bridge irb ! interface Loopback1 ip address 172.29.72.25 255.255.255.255 ! interface Ethernet0 description --- Ethernet to Customer --- ip address 10.0.0.250 255.255.255.0 no ip proxy-arp ip nat inside no ip route-cache no ip mroute-cache no keepalive no cdp enable hold-queue 100 out ! interface ATM0 description --- ADSL to Internode P230285 --- no ip address no ip route-cache no ip mroute-cache no atm ilmi-keepalive pvc 8/35
encapsulation aal5snap ! bundle-enable dsl operating-mode auto bridge-group 1 hold-queue 224 in ! interface BVI1 description --- Bridging Interface --- ip address 150.101.179.246 255.255.255.252 ip nat outside no ip route-cache no ip mroute-cache crypto map insnetvpn ! ip default-gateway 150.101.179.245 ip nat inside source static tcp 10.0.0.253 25 150.101.179.246 25 extendable ip nat inside source static tcp 10.0.0.254 3389 150.101.179.246 3389 extendable ip nat inside source route-map insnetnat interface Loopback1 overload ip nat inside source route-map internetnat interface BVI1 overload ip classless ip forward-protocol udp netbios-ss ip route 0.0.0.0 0.0.0.0 150.101.179.245 ip route 172.27.1.0 255.255.255.0 202.12.184.137 ip route 10.125.0.0 255.255.0.0 202.12.184.137 no ip http server no ip pim bidir-enable ! access-list 101 permit ip 10.0.0.0 0.0.0.255 172.27.1.0 0.0.0.255 access-list 101 permit ip host 172.29.72.25 172.27.1.0 0.0.0.255 access-list 101 permit ip 10.0.0.0 0.0.0.255 10.125.0.0 0.0.255.255 access-list 101 permit ip host 172.29.72.25 10.125.0.0 0.0.255.255 access-list 102 deny ip 10.0.0.0 0.0.0.255 172.27.1.0 0.0.0.255 access-list 102 deny ip 10.0.0.0 0.0.0.255 10.125.0.0 0.0.255.255 access-list 102 permit ip 10.0.0.0 0.0.0.255 any
no cdp run ! route-map internetnat permit 1 match ip address 102 ! route-map insnetnat permit 1 match ip address 101 ! bridge 1 protocol ieee bridge 1 route ip ! line con 0 stopbits 1 line vty 0 4 password XXXYYYZZZ login local
