VPN3005 and AD
Sep 21, 2006 3 Replies
Jump to replies (3)
I have configured my Cisco VPN 3005 to authenticate users to AD when they connect. This works fine for WebVPN, but I cannot get VPN client users to authenticate. Cisco VPN clients and Windows VPN clients fail.
When I use an internally configured username, the Cisco VPN client connects OK, but not the Windows client.
Am I missing something?
Thanks for any help!!
Russ
Hi Russ,
You may wish to investigate these steps:
Step 1. Check to see that the VPN Client user is supplying the correct username and password.
Step 2. Verify that the username and password are present in the database.
If you are using the VPN 3005 Concentrator as the remote server, you can verify the username and password.
Select Configuration > System > Servers > Authentication, then select Authentication Server, and click Test.
When prompted, enter the username and password.
If authentication is rejected, the username and password are not matching.
If you receive an authentication error ("No response from server"), continue to step 3.
Step 3. Verify that you have configured communication parameters for the authentication server properly.
Also, ping the authentication server to verify connectivity.
Hope this helps.
How are you authenticating against AD??? RADIUS via MS IAS?? CSACS??
check the security log on your domain controller for IAS events if yo'ure using IAS. make sure the RADIUS/TAC+ password is right on both devices. (it probably is if webvpn users are ok).... look in the filterable event log for errors also...
Thanks for the replies.
Authentication from the VPM3005 works fine. I can test the credentials successfully from the System>Servers>Authentication>Test option.
Also, when using WebVPN the user can use their domain credentials without any issues.
Domain authentication is direct using Kerberos server configures in the System>Servers>Authentication menu.
Russ
