Voip and load-sharing per-packet
Apr 27, 2005 1 Replies
I have two routers 1760 which connect together via two T1s with load-sharing per-packet option. The documentation says that this may cause problem with VOIP because of arriving-disorderedly packets.
In my case, I do have some phones using voip. These phones are on one side connecting to the phone server on the other side.
Is it possible to specify all connections to a specific ip address ( the address of the phone server ) not to use load-sharing per-packet options ?
Thanks for your advice,
DT
You are introducing a situation that guarantees jitter and voice cutting in and out.
Absolutely.
Run all RTP traffic over one of the T1s... just PBR matching on UDP ports
16384 to 32768 and specify its next hop to one of the T1s...
Jonathan
