Trouble with CCME and VIC2-4FXO; IOS 12.4(9)T
Sep 07, 2006 4 Replies
Jump to replies (4)
Trouble with CCME and VIC2-4FXO; IOS 12.4(9)T open original image
I am having trouble making ougoing cal or answering incoming call. Whwn I try to call out phone errors with the message unknown number. For incoming call, it rings but when I pick the call nothing happens, put thr rciever back on hook, the phone carries on ringing. I am in UK and just trying to set up test system with one analogue. Any help will be most appreciated. My config of the 2811 router is posted below. Thank you.
hostname Test-CME ! boot-start-marker boot-end-marker ! ! no aaa new-model ! resource policy ! network-clock-participate wic 0 network-clock-participate wic 1 ! ip cef no ip dhcp use vrf connected ip dhcp excluded-address 10.10.10.1 10.10.10.10 ip dhcp excluded-address 10.139.139.1 10.139.139.10 ! ip dhcp pool host network 10.10.10.0 255.255.255.0 default-router 10.10.10.1 option 150 ip 10.10.10.1 ! ip dhcp pool data network 10.139.139.0 255.255.255.0 default-router 10.139.139.1 dns-server 10.139.139.5 ! ! ! ! voice-card 0 no dspfarm ! ! voice service voip allow-connections h323 to h323 allow-connections h323 to sip allow-connections sip to h323 allow-connections sip to sip supplementary-service h450.12 h323 sip header-passing registrar server expires max 3600 min 3600 ! ! !
! interface FastEthernet0/0 no ip address shutdown duplex auto speed auto ! interface FastEthernet0/1 no ip address no ip mroute-cache duplex auto speed auto no shut ! interface FastEthernet0/1.2 description ** Data VLAN ** encapsulation dot1Q 2 ip address 10.139.139.1 255.255.255.0 ! interface FastEthernet0/1.3 description ** Voice VLAN ** encapsulation dot1Q 3 ip address 10.10.10.1 255.255.255.0 ! ! ! ip http server ip http authentication local no ip http secure-server ip http path flash: ! ! ! tftp-server flash:S00104000100.sbn tftp-server flash:TERM41.7-0-3-0S.loads tftp-server flash:term61.default.loads tftp-server flash:term41.default.loads tftp-server flash:CVM41.2-0-2-26.sbn tftp-server flash:cnu41.2-7-6-26.sbn tftp-server flash:Jar41.2-9-2-26.sbn tftp-server flash:term70.default.loads tftp-server flash:term71.default.loads tftp-server flash:cnu70.2-7-6-26.sbn tftp-server flash:Jar70.2-9-2-26.sbn tftp-server flash:TERM70.7-0-3-0S.loads tftp-server flash:CVM70.2-0-2-26.sbn ! control-plane ! ! ! ! voice-port 0/3/0 connection plar opx 202 caller-id enable ! ! ! dial-peer voice 1 pots incoming called-number . destination-pattern 9T port 0/3/0 ! ! ! ! telephony-service load 7914 S00104000100 load 7941 TERM41.7-0-3-0S load 7961 TERM41.7-0-3-0S load 7970 TERM70.7-0-3-0S max-ephones 20 max-dn 40 ip source-address 10.10.10.1 port 2000 calling-number initiator service phone videoCapability 1 system message MKC CME url services http://10.10.10.1/voiceview/common/login.do url authentication http://10.10.10.1/voiceview/authentication/authenticate.do time-zone 21 date-format dd-mm-yy voicemail 600 max-conferences 8 gain -6 call-forward pattern .T call-forward system redirecting-expanded moh music-on-hold.au web admin system name mkcsupport secret 0 test dn-webedit time-webedit transfer-system full-consult dss transfer-pattern 9.T secondary-dialtone 9 create cnf-files ! ! ephone-dn 1 dual-line number 201 label 201 description Sarah name Sarah ! ! ephone-dn 2 dual-line number 202 label 202 description Vitthal name User2 Vitthal ! ! ephone-dn 3 dual-line number 203 secondary label 203 description Neil name User3 Neil ! ! ephone-dn 7 number 701 park-slot ! ! ephone-dn 8 number 702 park-slot ! ! ephone 1 video username "user1" password 201 mac-address 0018.18EE.947F type 7961 addon 1 7914 button 1:1 ! ! ephone 2 video username "user2" password 202 mac-address 0018.18BB.B973 type 7941 button 1:2 ! ! ! ephone 3 video username "user3" password 203 mac-address 0018.1885.6BA2 type 7970 button 1:3 ! ! ! ! ! ! line con 0 line aux 0 line vty 0 4 password Mkc1986 login ! scheduler allocate 20000 1000 ntp master
Hi Vitthal,
You may wish to investigate Cisco's Understanding FXO Disconnect Problem:
Hope this helps.
Brad Reese Cisco IOS Software - Compatible Partner Matrix by Technology
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant BradReese.Com - Global Cisco Systems Pre-Sales Support
Hi Brad
Thanks for the link. I have read through the document and have will tried some of the suggestions without any lucky out some. Any other hint will be most appreciated.
Regards,
Vitthal
wrote:
Hi Vitthal,
Regarding your "outbound call issue" try this web page
and configuring voice ports:
Sincerely,
Brad Reese Cisco Repair
Hi Brad
Thanks for the links. Just had a quick read through. I will get back to you once I have tried some of the suggestions.
Regards,
Vitthal
wrote:
