Translation between router
Jul 14, 2008 0 Replies
Hello
I have a problem with nat translation.
I have a server (A) with two software instance. The instance work on 7700 TCP and 7800 TCP.
On the other side of router i have a software (B) we listen only on 8000 TCP.
It is possible to forward all (A) communications to (B).
Thanks for you support
