Static Nat ? port forward ? issue - novice
Feb 10, 2007 2 Replies
Static Nat ? port forward ? issue - novice open original image
Hi if you can help a novice Id appreciates it.
I have a 1800 series router with 2 Fast Ethernet Interfaces:
External and Internal
External IP - Internet
Internal IP addressing class C (say 192.168.10.0)
As I understand the router is doing Nat overload so with an access list
192.168.10.0 0.0.0.255 ? I understand the wild card mask etc.
What I would like to do is to forward requests on the external interface to an Internal server.
External IP:80 - internal 192.168.10.1:80 (For example)
If someone could help me or point me in the right direction Id appreciate it - also what is the correct terminology for what I want to accomplish? Would it be a static Nat?
Many thanks
Craig.
Static NAT it is.
Configuring Network Address Translation: Getting Started
