Split Horizon as I know it is a technique used by some routing protocols to prevent routing loops. I'm not sure it can be applied to load balancing two ISPs. Maybe you should look into specialized hardware to solve this issue. Link load balancers like or way to use different…
I wounder if somebody could point me in the right direction for info on setting up Split Horizons? Not sure if I have the terms correct. Basicly I have two ISP lines and would like to use both for internet traffic either load-balanced or by IP.
Thanks in advance. J
Sorry...Yes it is not working.... I have not done much yet I was looking for...
H
Hoffa
or
way to use different ISPs for Internet traffic is by applying for a dedicated AS and IP-range and use BGP to route the traffic over the different ISPs but this is very difficult to set up so unless you're system is highly mission critical I'd go for dedicated hardware solution.
Regards Fredrik Hofgren
thejayman wrote:
J
James
Just found this after a google search:-
James
Hoffa wrote:
T
thejayman
Report Content
ASAP.
