SMTP inbound and 8 static ip.
Apr 20, 2008 0 Replies
Hi all.
I am replacing my company router with a Cisco 831. basic configuration was done, but SMTP not working well.
Here's my case:
[internet]----[ADSL modem]----[Cisco 831]----[192.168.0.x]
wan: 61.x.x.x
8 static IP 60.x.x.104 - 60.x.x.111
All internal IP(192.168.0.x) use the WAN IP to access the internet.
First problem, when I try to test the SMTP server (192.168.0.10) from home. There are no reply at all. I know that telnet of windows not work, I tried putty raw mode, also no reply. however, http work.
Second problem, how can i set route so that my SMTP server ( 192.168.0.10 ) use the dedicated static IP (60.x.x.106) to send packet out? Some server's junk mail filter may treat incoming mail as spam if the server IP not match...
Here's my configration. Please suggest and Many THANKS!
Building configuration...
Current configuration : 3691 bytes ! version 12.3 no service pad service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname Cisco ! enable secret 5 $!3081723ase ! clock timezone GMT no aaa new-model ip subnet-zero ip tcp mss 1420 ip tcp path-mtu-discovery ! ! ip audit notify log ip audit po max-events 100 no ftp-server write-enable ! ! interface Ethernet0 ip address 192.168.0.1 255.255.255.0 secondary ip address 60.x.x.105 255.255.255.248 ip nat inside ip tcp adjust-mss 1420 pppoe enable no cdp enable hold-queue 32 in hold-queue 100 out ! interface Ethernet1 no ip address ip nat outside ip tcp adjust-mss 1420 duplex auto pppoe enable pppoe-client dial-pool-number 1 no cdp enable ! interface FastEthernet1 no ip address duplex auto speed auto ! interface FastEthernet2 no ip address duplex auto speed auto ! interface FastEthernet3 no ip address duplex auto speed auto ! interface FastEthernet4 no ip address duplex auto speed auto ! interface Dialer1 ip address negotiated ip access-group 101 in ip mtu 1492 ip nat outside encapsulation ppp no ip route-cache ip tcp adjust-mss 1420 no ip mroute-cache dialer pool 1 no cdp enable ppp authentication pap callin ppp pap sent-username 528123@ISP1 password 7 3123871289 ! ip nat pool wanpool 60.x.x.106 60.x.x.110 netmask 255.255.255.248 ip nat inside source list 1 interface Dialer1 overload ip nat inside source static tcp 192.168.0.10 25 60.x.x.106 25 extendable ip nat inside source static tcp 192.168.0.10 80 60.x.x.106 80 extendable
ip classless ip route 0.0.0.0 0.0.0.0 Dialer1 no ip http server no ip http secure-server ! access-list 1 permit 192.168.0.0 0.0.0.255 access-list 101 permit ip any any no cdp run ! line con 0 exec-timeout 120 0 password 7 xxxxxxxxxxxxxxxxxxx login no modem enable stopbits 1 line aux 0 stopbits 1 line vty 0 4 exec-timeout 120 0 password 7 xxxxxxxxxxxxxxx login length 0 ! scheduler max-task-time 5000 sntp server 202.123.165.147 ! end
