site-to-site VPN between a 1721 and a 857
Aug 31, 2005 2 Replies
Your config files are too long to read thru :)
Anyway, I think the problem is on the NAT set up. I think you can try by starting from simple configuration with the least access-list and no static NAT to make sure it work properly then you can add those extra access-lists and static NAT later.
DT
Hello there. I am rather new at this, but I spent quite some time on it with not much of a result so far. Here's the situation : I have setup a site to site VPN between a Cisco 1721 and a Cisco 857. The tunnel comes up, and I can do some things accross it, like :
- from a machine in LAN A, I can ping the interface of the other router in LAN B.
- I can do the opposite as well.
- but, when I ping a machine of LAN B from a machine of LAN A, only the first packet comes back ! This is also true if I ping A from B. If I wait a couple minutes, I can do it again, and with the same result : first packet gets an answer, not the others!
For those interested in the problem, here are sanitized configs :
On the 857 side :
Hello. Thanks for the tip, I'll give that a go. Sorry for the long configs, but I thought if I reduced them I might just as well remove the cause of the problem!
R.
a écrit dans le message de news: snipped-for-privacy@g43g2000cwa.googlegroups.com...
