VPN site to site initial connection problem
Sep 13, 2006 6 Replies
Jump to replies (6)
I have a strange problem. I have a PIX 515 at central office and a PIX
506e at the remote office.
We have VPN site to site working.
When the VPN times out the VPN tunnel comes down.
The strange things is:
when i try to send a ping from the central office to the remote office the ping fails, however, a vpn is created (show crytpo isakmp sa).
If i ping from the remote office to the central office the ping works. After the this i am able to ping from the central office to the remote office.
I want to be able to start the connection from the central office. What is the problem?
Thanks
Firstly,If the PIX IOS versions are different on the peers ,this could be one of the issue.
Secondly, In the Site to Site VPN Tunnel, if individual hosts are added instead of the Network address(10.0.0.0/8), we have to ping from either ends at the same time to bring up the VPN Tunnel.
Please check the same and reply
Regards Sunil
Charolette wrote:
Sorry for my ignorance, i am not sure what you mean in the second point. I would assume that site-to-site VPN between Cisco PIX's should be able to work seemlessly. Anyway, when hosts are added to either end of the network, they are able to use the same VPN tunnel. As long as a device from the remote office sends a ping packet, this will allow the head office to come through the VPN tunnel.
Thanks
snipped-for-privacy@gmail.com wrote:
Is the remote office using a dynamic or static IP Address? If it is dynamic then you must initiate the VPN connection from the remote office as the central office has no way of knowing the IP Address.
Also, try adding "isakmp keepalive 30 5" to the remote office PIX, as far as I know this command should keep the VPN tunnel alive.
James
Charolette wrote:
I am not sure what you mean about whether it is static or dynamic. But both ends have their own private address. The head office is using a
10.0.0.0 network and the remote office is using a 192.168.0.0 network.
Thanks
James wrote:
The outside interface address of the remote office PIX - is it a static address or assigned by the ISP using DHCP?
