SIP on CIsco Routers
Mar 30, 2005 4 Replies
Jump to replies (4)
SIP on CIsco Routers open original image
Hi, been looking for someone who's tried this...
I have a Vwic module for a 2600, and I wonder if I can connect an analogue phone to it to use as a sip gateway....
furthermore I wonder if it is possible to connect a pstn line and use the router as a SIP gateway for imbound calls ?
anyone tried this ?
Will
What exactly do you have?
The only VWICs are T1 interfaces.
If you have a VIC-2FXS you'll need to put it in an NM-1V or NM-2V (or any of the newer more complex ones, but these are the basic ones), and with the right IOS load, you'll be able to run a phone off the VIC-2FXS card.
And you'd need a VIC-2FXO card to do that. Again, it'd have to go into a NM-1V or NM-2V card to insert into the 2600. Obviously, if you wanted to do both inbound and outbond in the same box, you'll want the NM-2V so you can stick both the VIC-2FXS and VIC-2FXO cards in, and you can have two calls in and two calls out to phones.
sorry to clarify...
I have a VIC-2FXO and an NM2V
are you saying that I can configure this so that I can take PSTN calls in and drop them onto an IP handset... or for the time being pc ?
sorry, I know very little about voice on cisco I've done all my VOIP on Avaya... my cisco exp. is all on bigger stuff...
thanks very much for any info !
W.
Usually, the SIP infrastructure is a bit more involved than that, but the cisco docs have some pretty wide range of configuration options that could degernate into your test case.
