Setting up VPN
Mar 30, 2006 1 Replies
I've got a Cisco 877 router/DSL modem running IOS 12.3.
Setting up EasyVPN server seems straightforward, but it appears to only work with the Cisco VPN client. Is there some way to set up the router as a VPN server that will work with other clients, such as the built-in VPN software on Windows XP?
I've looked for instructions, but all I can find are instructions for setting up an EasyVPN server, or setting up a peer-to-peer VPN connection with another Cisco box.
Thanks, Mark
Yes.
Set up a vpn group for pptp dialin.
Sorry, I don't know the sequence of configuration commands, but see
