Second ISP
Oct 31, 2007 6 Replies
Jump to replies (6)
Second ISP open original image
If I add a second Internet feed and can't run BGP, how do I tell my network to send traffic out via the new router?
BGP is just your EGP. All you need to do to make sure traffic goes out both links is ensure that whatever routing protocol is running between your network/core and the internet routers has equal costs or a preferred metric for whatever internet pipe you wish to use. Also make sure that the second ISP router does not have a better default route out the other internet router, and is sending traffic out that it receives from the core. All of this can be done with show ip route
0.0.0.0 commands.
Balancing internet traffic back in is a completely different story as I'm sure you are aware......
Currently, the network is simple and there is only one way out so we are only using static routes. This is a school and Internet access via the school board is intermittent. We simply want to get cable or DSL for an alternate path out and back. Does this require a routing protocol? If so, will RIP do?
Static will load balance, but if one fails, you may be SOL. You could do statics and point to the interface rather than the next hop (if its point to point), but I would recommend a routing protocol. Rip should do multi-path load balancing.
Here's a way to do it based on protocol:
! First setup object tracking to ping your ISP's routers.
ip sla 1 icmp-echo timeout 1000 frequency 5 ip sla schedule 1 life forever start-time now ip sla 2 icmp-echo timeout 1000 frequency 5 ip sla schedule 1 life forever start-time now
! Then define your default routes. We're going to use ISP 2 as the preferred default route, since ! it has a lower metric. If the tracking object goes down, it will failover to ISP2.
ip route 0.0.0.0 0.0.0.0 20 track 1 ip route 0.0.0.0 0.0.0.0 track 2
! Now create the ACL that will match traffic you want to route differently than your default route.
ip access-list extended PBR permit tcp 10.233.165.0 0.0.0.255 any eq smtp permit tcp 10.233.165.0 0.0.0.255 any eq www
! Setup the route map to match anything in the ACL to be routed out ISP1. If the ISP1 upstream router is down, it will failover to ISP2 (our normal default route).
route-map RULES permit 10 description Tracking object routing - PBR ACL for bypass match ip address PBR set ip next-hop verify-availability 1 track 1
! Lastly, you need to setup NAT according to the ISP that you're routing traffic to. Optional: Use a deny statement if you have lan to lan vpn's.
ip access-list extended nat_rule deny ip 10.233.160.0 0.0.31.255 10.233.148.0 0.0.0.255 permit ip 10.233.165.0 0.0.0.255 any
! Now create the route map to NAT according to which interface the traffic is leaving.
route-map NAT_MAP_ISP2 permit 10 description To nat outbound traffic to ISP address block match ip address nat_rule match interface fa0/1 ! route-map NAT_MAP_ISP1 permit 10 description To nat outbound traffic to ISP address block match ip address nat_rule match interface fa0/2
! Dont' forget to put ip nat outside statements on each of your Internet facing interfaces and ip nat inside on your LAN interface.
If you are using NAT, then take a look at Cisco doc "IOS NAT Load- balancing for Two ISP Connections"
